Make breakable - Continous Fracture
Drughi
Hi Johannes,
There doesn't seem to be an exact way (at least not that I can see). But there are a couple of parameters you can change to roughly achieve this:
Minimum volume: Anything below this threshold wont fracture and you can calculate the fractured pieces volume in a wrangle.
Points by area: By lowering this value you control the amount of fractures. Less fractures, the bigger the pieces.
Maximum Fractures: Increase this number to keep fracturing the RBD object until all pieces have fractured to their smallest size.
Hope this helps!
