Q: noise's offset will change freq?!
hmy911
Use noise vop for simple river
Hi everyone, I am trying to use noise deform for river
Inspired by gameDev's  flow map
Use surface velocity direction multiple time then plug into the offset of noise
Looks great in begin
But In the end, it will change freq of noise
freq is getting high and higher
I don’t know why?
any advice thanks~
video
hip
Edited by hmy911
i think the width of your river is far too wide for that tight curve. The bend is getting crunched.
to see it better after you polyframe3, add polyexpand2d, Offset surfaces, increase the offset and you'll see the bend get crushed against
itself.
or to go the other way. if you shorten your line2 to about 1.8...there's no self collapsing at the  tight bend
