2 sided shader with bump not working
I'm not sure what I'm doing wrong here, I've googled around and not found the answer.
I have a scene with some very thin geometry that needs to be glossy plastic on one side and dimpled foil on the other - I'm using a twosided VOP and the basics work but the bump just doesn't come through. I'm using noise displacement bump.
I can't share the scene but attached is a mockup exhibiting the same behaviour. Also a couple of renders - the side with no butterflies on in the no_bump render should be like the bumped metal in the other still.
I'm missing something obvious I suspect but I can't find it...!
Thanks for reading
2Sided.hiplc
if you want two side material with bumped metal  on one side and glossy plastic on the other, i presume it is the best choice to use bump instead of displacement, because displacement has influence to all geometry. Here two pictures: first with displacement, second with bump.
Principled shader does not have ability to use noise for bump by default. You can change a shader and use "noise displacement bump" tab to control bump. See hip.
2Sided_01.hipncFetching info...
Edited by vicvvsh
