dissipate custom scalar field
Ultraman
the issue is that you are copying temperature to your field every timestep, so the dissipation is applied always only for one step
in other words your field currently is almost the same as temperature, so unless you dissipate (cool down) temperature field more your field will not be much different by Dissipating it only for one step
