Mplay Loader
IIIROFLIII
Hi All,
I have a little question about Mplay.
I want to make an HDA which can launch a sequence image file in Mplay.
Actually I use the subprocess.Popen(['mplay', 'path']) command.
But I want to configure this Mplay session (setting FPS and other things;)
But I don't understand how to do it.
I search in the documentation and internet, and I can't find a hou.something which can launch Mplay, maybe to have a connection between Mplay and the current houdini session.
Can you give me a basic structure of python code to do this kind of things?
Thanks
import subprocess
subprocess.Popen(r"C:\Program Files\Side Effects Software\Houdini 18.0.391\bin\mplay.exe -f 1 100 1 -r 30 D:\Houdini\render\preview\v014\v014.$F.jpg")
you can use flags to configure mplay session like -f for frame range -r for fps etc, check out the docs for more info: https://www.sidefx.com/docs/houdini/mplay/mplay_options.html
