Drughi Posted April 23, 2020 Share Posted April 23, 2020 (edited) Hi! I have a question regarding Tops (File attached). You have 3 Caches: first cache is a Sim; next cache only one frame, but dependent on the first frame of the sim; and a final cache dependent on both. If I try to do this somehow it fails always. Only after a 2nd try it works if the inital sim is allready cached. Odforce_Tops_001.hiplc Edited April 23, 2020 by Drughi Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted April 23, 2020 Share Posted April 23, 2020 (edited) Here is your example file with some modifications and two ways of doing it! I hope this helps you! Cheers! Alejandro aeb_Odforce_Tops_001.hiplc Edited April 23, 2020 by Pazuzu 1 Quote Link to comment Share on other sites More sharing options...
Drughi Posted April 24, 2020 Author Share Posted April 24, 2020 Thanks Alejandro! But I'm not sure if you still be able to cook a frame range with each frame as an individual process this way? Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted April 28, 2020 Share Posted April 28, 2020 No problem! Yes you can, thats why I did the example file with both options, the entire frame range as a job and each frame as a job as well. 1 Quote Link to comment Share on other sites More sharing options...
Drughi Posted April 28, 2020 Author Share Posted April 28, 2020 Now i get it. thanks again! Highly appreciated! Quote Link to comment Share on other sites More sharing options...
