Unable to find IPRViewer in Houdini 18
ninhenzo64
Hi people,
I had some code which I was running to find the rendered image in the "Render View" pane and save it to file.
    _desktop = hou.ui.curDesktop()
    _ipr = _desktop.paneTabOfType(hou.paneTabType.IPRViewer)
    _ipr.saveFrame(_file)
This was running fine in Houdini 17. However, since updating to Houdini 18 (I'm using 18.0.440), the desktop object seems like it can't find the IPR pane, the paneTabOfType method is returning None.
Anyone have any ideas what I can do to get this working?
Thanks,
Henry
22 hours ago, ninhenzo64 said:
Hi people,
Thanks,
Henry
Your IPR being your output mantra_IPR? unless you are using another render engine?
  • 1 year later...
For those coming back to this, it looks like that way is deprecated. But you can do something similar like this
_desktops = hou.ui.currentPaneTabs()
_ipr = [x for x in _desktops if x.type()==hou.paneTabType.IPRViewer][0]
_ipr.saveFrame()
