spev Posted September 21, 2006 Share Posted September 21, 2006 I am probably missing something obvious but an inspection of the attached scene will show the oddness that I have experienced. I am trying a simple boolean op using the cookie SOP between a simple sphere and box. All is fine if you translate the sphere into a position then aplly the cookie sop. The problems come when I use a scatter SOP to place my sphere. The cookie SOP does not work the in the way that I am expecting...not sure why...is it a bug or my noviceness? Any help would be gratefully recieved. Thanks in advance Sorry included file did not upload as error:- The requested file upload failed because suitable permissions have not been enabled on the 'uploads' directory. Please contact the board administrator and inform them of this error. Will try to upload later but I think you get the idea. Quote Link to comment Share on other sites More sharing options...
jhiggins Posted October 26, 2006 Share Posted October 26, 2006 yeah i see what i mean, at least i think i do. before pumping the inputs into the cookie sop, add convert sops to convert them. i've attached a sample file. disabling the the converts disables the cookie, which seems like a bug to me! yeah i see what i mean, at least i think i do.before pumping the inputs into the cookie sop, add convert sops to convert them. i've attached a sample file. disabling the the converts disables the cookie, which seems like a bug to me! sorry, i meant to say i see what YOU mean... Quote Link to comment Share on other sites More sharing options...
spev Posted October 26, 2006 Author Share Posted October 26, 2006 yeah i see what i mean, at least i think i do.before pumping the inputs into the cookie sop, add convert sops to convert them. i've attached a sample file. disabling the the converts disables the cookie, which seems like a bug to me! sorry, i meant to say i see what YOU mean... Thanks for your help jeffrey also turning jitter on sorts this issue out sidefx support now know about this Thanks again Quote Link to comment Share on other sites More sharing options...
stevenong Posted October 26, 2006 Share Posted October 26, 2006 Hi there, The Cookie SOP only works with polys so without the Convert SOP, it will not give you any result. Cheers! steven Quote Link to comment Share on other sites More sharing options...
