Ultraman Posted May 12, 2020 Share Posted May 12, 2020 (edited) Hey Guys . I want to Ask how can Expand my Velocity Field without using any divergence (my vel coming from sop source ) . maybe below picture tell more , what i'm talking .. Thanks as Always Edited May 12, 2020 by Milad Savar . Quote Link to comment Share on other sites More sharing options...
anim Posted May 12, 2020 Share Posted May 12, 2020 if you are talking about smoke/pyro solver, then the only way to have true expansion is using divergence, since the main point of fluid sim is that it's nondivergent so that you either provide goal divergence that will allow it to expand or contract or avoid pressure projection altogether and therefore lose fluid motion 2 Quote Link to comment Share on other sites More sharing options...
Ultraman Posted May 12, 2020 Author Share Posted May 12, 2020 1 hour ago, anim said: if you are talking about smoke/pyro solver, then the only way to have true expansion is using divergence, since the main point of fluid sim is that it's nondivergent so that you either provide goal divergence that will allow it to expand or contract or avoid pressure projection altogether and therefore lose fluid motion thanks for quick response Tomas . there is hip file .. and i'm taking about pyro stuff i know true expand is divergence but i need only expand vel field to more cover my density around ( it's possible in sop , but i wanna know how can do it in DOP ) Example.hip Quote Link to comment Share on other sites More sharing options...
k2p8 Posted May 12, 2020 Share Posted May 12, 2020 You may try to tweak the gasresizefluiddynamic. If you dive in, you ll find a sopsolver with ResizeBounds data. Inside merge a bound of your velfield from sop with the out node (don't forget to tag the merge node as display). It some sort of a minimum of the 2 bounds so your sim will expand of the vel field at the next frame. 1 Quote Link to comment Share on other sites More sharing options...
Ultraman Posted May 12, 2020 Author Share Posted May 12, 2020 (edited) 1 hour ago, k2p8 said: You may try to tweak the gasresizefluiddynamic. If you dive in, you ll find a sopsolver with ResizeBounds data. Inside merge a bound of your velfield from sop with the out node (don't forget to tag the merge node as display). It some sort of a minimum of the 2 bounds so your sim will expand of the vel field at the next frame. thanks , i'm not talk about resize container , if is it your means . ( i know my question is little dump , sorry about that ) .. i'm speak about expand vortex vel , which coming from sop source Edited May 12, 2020 by Milad Savar Quote Link to comment Share on other sites More sharing options...
toadstorm Posted May 12, 2020 Share Posted May 12, 2020 I have a DOP solution for you, but to be honest you might just want to make your vortex bigger in SOPs rather than handle it in DOPs. What you need to do is use the Gas Extrapolate DOP, along with an SDF generated from the original volume source SOP, to expand the vortex's reach. This means you need to make a surface SDF in SOPs that's large enough to handle the widest bounds that your vortex would need to reach. You then have to source v to a temporary field instead of directly to vel, run Gas Extrapolate on that tempvel field, then use Gas Linear Combination to add tempvel to vel and complete the sourcing operation. extrapolate_vel_toadstorm.hiplc 1 Quote Link to comment Share on other sites More sharing options...
Ultraman Posted May 12, 2020 Author Share Posted May 12, 2020 1 hour ago, toadstorm said: I have a DOP solution for you, but to be honest you might just want to make your vortex bigger in SOPs rather than handle it in DOPs. What you need to do is use the Gas Extrapolate DOP, along with an SDF generated from the original volume source SOP, to expand the vortex's reach. This means you need to make a surface SDF in SOPs that's large enough to handle the widest bounds that your vortex would need to reach. You then have to source v to a temporary field instead of directly to vel, run Gas Extrapolate on that tempvel field, then use Gas Linear Combination to add tempvel to vel and complete the sourcing operation. extrapolate_vel_toadstorm.hiplc Thanks a lot Henry , that what i wanted .. Quote Link to comment Share on other sites More sharing options...
