Environment Variables issue
pedromosh
Hi guys,
I'm using Houdini indie 18.0.460 with Redshift 3.2
When I add the env. variables for redshift in the houdini.env, the mops library and the sidefx labs automatically stop working. Anyone add this problem?
Thanks
is probably an error probably `&` that guy you have somewhere repeated twice or isn't in the right place, etc, just guessing here.  The best thing to do is if you post you .env file here.
Houdini.env
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup.  They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
#    VAR = VALUE
# Values may be quoted
#    VAR = "VALUE"
# Values may be empty
#    VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
#MOPS
MOPS="D:/Dummy/Tools/MOPS"
QLIB="/path/to/qlib"
HOUDINI_PATH=$HOUDINI_PATH;$QLIB;$MOPS;&
#QLIB
QLIB="D:/Dummy/Tools/QLIB/otls"
HOUDINI_OTLSCAN_PATH=@/otls;$QLIB/base;$QLIB/future;$QLIB/experimental
#REDSHIFT
HOUDINI_DSO_ERROR = 2
PATH = "C:/ProgramData/Redshift/bin;$PATH"
HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/18.0.460;&"
#Denoiser
HOUDINI_NVIDIA_OPTIX_DSO_PATH = C:/Users/PMAIA-PC/Documents/houdini18.0/optix
You're redefining HOUDINI_PATH there at the end without including $HOUDINI_PATH; to make sure you're adding your new path definition to the existing one. Your last HOUDINI_PATH line should be:
HOUDINI_PATH = "$HOUDINI_PATH;C:/ProgramData/Redshift/Plugins/Houdini/18.0.460;&"
If you want to know more about the guts of editing the environment file, I wrote an article about this on my blog: https://www.toadstorm.com/blog/?p=678
That said, I'd recommend you switch to using packages instead of using the Houdini.env. They're a lot easier to configure. I have another article here you can read about packages, and it comes with a sample Redshift package you can use: https://www.toadstorm.com/blog/?p=722
