Steadicam Posted May 17, 2020 Share Posted May 17, 2020 I need to revolve a curve around an axis between two points. I might be missing something obvious but I can't figure out how to do this in obj/modeling. the Revolve tool would otherwise be perfect if it wasn't requiring the "direction" value to function. I can't figure a way to align that automatically with a point's XYZ from the origin. Any suggestions? Quote Link to comment Share on other sites More sharing options...
anim Posted May 17, 2020 Share Posted May 17, 2020 (edited) not sure what is your exact case, but here is an example that revolves using axis between first and last points of the input curve revolve_between_first_last_points.hip Edited May 17, 2020 by anim Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 18, 2020 Share Posted May 18, 2020 would prolly help to understand if you click on the Axis Direction label in anim's file above, to see the snippets instead of resultant numbers Quote Link to comment Share on other sites More sharing options...
Steadishot Posted May 18, 2020 Share Posted May 18, 2020 Thanks!!!! Quote Link to comment Share on other sites More sharing options...
