eunchae Posted May 20, 2020 Share Posted May 20, 2020 Hello, everyone. I am working on a saliva. I want to work with vellum ... The split does not break even when using weld. Look at my hip file and let me know what's wrong. Thank you. saliva_test.hipnc Quote Link to comment Share on other sites More sharing options...
anim Posted May 20, 2020 Share Posted May 20, 2020 4 hours ago, eunchae said: The split does not break even when using weld. what are you welding? there is no split in your curves I added some splits, also you had some additional Stitch constraints being created in the dops so I disabled those otherwise they'd stitch those breaks back again saliva_test_fix.hipnc Quote Link to comment Share on other sites More sharing options...
eunchae Posted May 21, 2020 Author Share Posted May 21, 2020 (edited) 7 hours ago, anim said: what are you welding? there is no split in your curves I added some splits, also you had some additional Stitch constraints being created in the dops so I disabled those otherwise they'd stitch those breaks back again saliva_test_fix.hipnc Thanks for the reply. But I don't understand. I want to break the line.( By making some conditions ...) Grouped points to be cut and used a weld constraint, but this has no effect. I am not sure how to use it. Thank you. ( I am using Houdini version 17.5.) Edited May 21, 2020 by eunchae Quote Link to comment Share on other sites More sharing options...
anim Posted May 21, 2020 Share Posted May 21, 2020 here is file that will work in 17.5, and maybe even simpler technique, but essentially the same, the point is that you have to have the pieces separate to begin with and then Weld will just temporarily weld them until the threshold is reached saliva_test_fix_17.5.hipnc 1 1 Quote Link to comment Share on other sites More sharing options...
eunchae Posted May 21, 2020 Author Share Posted May 21, 2020 21 minutes ago, anim said: here is file that will work in 17.5, and maybe even simpler technique, but essentially the same, the point is that you have to have the pieces separate to begin with and then Weld will just temporarily weld them until the threshold is reached saliva_test_fix_17.5.hipnc Thank you very much for the answer! I think i know a little now. I tried this. However, some parts are not cut off. Can you help me? Thank you. saliva_test_2.hipnc Quote Link to comment Share on other sites More sharing options...
anim Posted May 21, 2020 Share Posted May 21, 2020 depends on your breaking threshold, it's too high, but also as I mentioned before 14 hours ago, anim said: you had some additional Stitch constraints being created in the dops so I disabled those otherwise they'd stitch those breaks back again you had that enabled again in your new file saliva_test_2_fix.hipnc 1 Quote Link to comment Share on other sites More sharing options...
eunchae Posted May 23, 2020 Author Share Posted May 23, 2020 On 2020. 5. 21. at 6:13 PM, anim said: depends on your breaking threshold, it's too high, but also as I mentioned before you had that enabled again in your new file saliva_test_2_fix.hipnc I was missing a lot. Thank you so much for your help !! Quote Link to comment Share on other sites More sharing options...
