About vellum's weld constaint
eunchae
  On 5/20/2020 at 1:34 PM, eunchae said:
The split does not break even when using weld.
what are you welding? there is no split in your curves
I added some splits, also you had some additional Stitch constraints being created in the dops so I disabled those otherwise they'd stitch those breaks back again
saliva_test_fix.hipnc
saliva_test_fix.hipncFetching info...
Thanks for the reply.
But I don't understand.
I want to break the line.( By making some conditions ...)
Grouped points to be cut and used a weld constraint, but this has no effect.
I am not sure how to use it.
Thank you. ( I am using Houdini version 17.5.)
Edited by eunchae
  On 5/21/2020 at 2:46 AM, anim said:
here is file that will work in 17.5, and maybe even simpler technique, but essentially the same, the point is that you have to have the pieces separate to begin with and then Weld will just temporarily weld them until the threshold is reached
saliva_test_fix_17.5.hipncFetching info...
Thank you very much for the answer!
I think i know a little now.
I tried this.
However, some parts are not cut off.
Can you help me?
Thank you.
saliva_test_2.hipnc
depends on your breaking threshold, it's too high, but also as I mentioned before
you had that enabled again in your new file
saliva_test_2_fix.hipnc
  • Thanks 1
