starion83 Posted May 20, 2020 Share Posted May 20, 2020 Hi everyone, I have a simple fracture simulation that I would like to use as collision geo in a vellum sim. However as vellum is particle based, and the collision geo is very low poly, I need to somehow increase the geo subdivisions for the fracture sim geo. I've looked at using the subdivide node, but this doesn't seem to work. I'm hoping this is a simple one and I'm just not aware of the right node to drop in! Thanks in advance! Glass.hiplc Quote Link to comment Share on other sites More sharing options...
anim Posted May 20, 2020 Share Posted May 20, 2020 On 5/20/2020 at 5:11 PM, starion83 said: However as vellum is particle based, and the collision geo is very low poly Expand Vellum collisions are not particle based so you shouldn't have any issue colliding against faces or edges however low poly your geo is Quote Link to comment Share on other sites More sharing options...
starion83 Posted May 20, 2020 Author Share Posted May 20, 2020 On 5/20/2020 at 5:19 PM, anim said: Vellum collisions are not particle based so you shouldn't have any issue colliding against faces or edges however low poly your geo is Expand Hey thanks for the fast reply Tomas, it sounds like I've misunderstood how vellum works! I thought that it was particle based (not sure where I've picked this up...) This would explain why vellum sim is only colliding with the geo points from the fracture sim, which is why I'm trying to subdivide it further. But it sounds like there is another way? Quote Link to comment Share on other sites More sharing options...
anim Posted May 20, 2020 Share Posted May 20, 2020 On 5/20/2020 at 5:23 PM, starion83 said: This would explain why vellum sim is only colliding with the geo points from the fracture sim Expand it actually wouldn't, as by default vellum should collide with faces, but I don't see any vellum setup in your file so it's difficult to pinpoint your problem if the hip file doesn't show it Quote Link to comment Share on other sites More sharing options...
anim Posted May 20, 2020 Share Posted May 20, 2020 I added a piece of cloth and seems to work fine on your glass, maybe you didn't unpack your colliders? Glass_mod.hiplc Quote Link to comment Share on other sites More sharing options...
starion83 Posted May 20, 2020 Author Share Posted May 20, 2020 On 5/20/2020 at 5:40 PM, anim said: it actually wouldn't, as by default vellum should collide with faces, but I don't see any vellum setup in your file so it's difficult to pinpoint your problem if the hip file doesn't show it Expand Sorry Tomas that last file didn't include the Vellum sim. I've attached it again. Also here is a screen cap of what's happening. The vellum is colliding only with a few points from the fracture rbd sim GlassAndVellum.hiplc Quote Link to comment Share on other sites More sharing options...
anim Posted May 20, 2020 Share Posted May 20, 2020 so as mentioned here, unpack your glass pieces before using them as collision geo for vellum Quote Link to comment Share on other sites More sharing options...
starion83 Posted May 20, 2020 Author Share Posted May 20, 2020 On 5/20/2020 at 6:00 PM, anim said: so as mentioned here, unpack your glass pieces before using them as collision geo for vellum Expand That was what was missing! Thanks so much Tomas, very much appreciated Quote Link to comment Share on other sites More sharing options...
