flcc Posted May 22, 2020 Share Posted May 22, 2020 Hi probably a noob question, but I work on an animation where in the timeline I must use a straigth (linear) curve. But as I move a keyframe the curve is no more straight. I must premanently click the straight tangent button. Pretty annoying. Checking the doc you must "set selected segment to..." -> straight. but it's just a temporary setting. It's the same as the straight tangent button. How do you permanently make a straigth or zero length tangent curve ? Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted May 22, 2020 Share Posted May 22, 2020 Hi, i know two ways to make it works, it may be more though: 1. Inside Animation Editor there is "Function" drop down menu at the bottom of the window. Select segment of animation curve and choose "linear()" 2. Inside Parameter tab - toggle animated parameter with LMB and you can see function type of animation curve ("bezier()" by default). You can set time slider between two keyframes and in field of animated parameter type "linear()". This change type of animation curve on segment between two keyframes. 1 Quote Link to comment Share on other sites More sharing options...
flcc Posted May 22, 2020 Author Share Posted May 22, 2020 (edited) 1 hour ago, vicvvsh said: 1. Inside Animation Editor there is "Function" drop down menu at the bottom of the window Thank you. it's exactly what i'm after. Edited May 22, 2020 by flcc Quote Link to comment Share on other sites More sharing options...
