Timeline : permanent Straight tangent ?
flcc
Hi
probably a noob question, but I work on  an animation where in the timeline I must use a straigth (linear) curve.
But as  I move a keyframe the curve is no more straight. I must premanently click the straight tangent button. Pretty annoying.
Checking the doc you must "set selected segment to..." -> straight. but it's just a temporary setting. It's the same as the straight tangent button.
How do you permanently make a straigth or zero length tangent curve ?
Hi,
i know two ways to make it works, it may be more though:
1. Inside Animation Editor there is "Function" drop down menu at the bottom of the window. Select segment of animation curve and choose "linear()"
2. Inside Parameter tab - toggle animated parameter with LMB and you can see function type of animation curve ("bezier()" by default). You can set time slider between two keyframes and in field of animated parameter type "linear()". This change type of animation curve on segment between two keyframes.
  • Thanks 1
