Gasupres doesn't work
Pavel K
A few of things.
On the gasupres node make sure you set the Fluid Type to Smoke, not Pyro.
Also, you have to drop down an attribute wrangle between the lores and the upres node to create a detail attribute named @timescale. When this attribute is missing the time scale defaults to 0, which is no motion. Set it to 1.0 to test, but try other values to speed up or slow down the upres.
On the output of the lores dopnet, you need to add temperature and vel fields which get forwarded to the upres network. Without those, the upres simulation won't work.
ap_smoke_upres.hiplc
  • Thanks 1
