mm VDB (Smoke) Combine for Houdini 17.x and over
matEvil
Hi there,
I want share for free my HDA for combine and export the cache of fluid from cluster system and convert it in VDB.
Download here
It's a open HDA so you can edit it if you want, please let me know if you do/did it and let me know if you use it in production.
It's free, but a little donation is grateful
Have a nice day
Matteo
video demo
https://youtu.be/dLj2CaWam7Q
  • 1 year later...
It works.
Obviously you should build a system for cluster and from shelf, for example, in Houdini 19 doesn't exist and you should do manually or you can switch to Sparse Systems (sometime works and some time should be better the old way).
Here my scene tested on Houdini 19
Matteo
mm_vdb_smoke_combinetest_19.hiplc
