HtoA motion blur
Hi There,
I can't figured out what I am doing wrong trying to apply motion blur to the simple sphere in my scene. The sphere is translated moving in -Y direction.
I did create velocity attrib as I presuming motion blur will need that.
Then I am going to the Motion Blur tab in Arnold in ROP and turn on transform keys and no motion blur at all.
Am I doing something not correct here?
Have you enabled motion blur on the Geometry node?  Under Geometry->Arnold->Motion Blur tab, there is a Velocity Blur parameter. It should be enabled by default, with v as the expected motion blur value to be used for calculations.
If that fails, check the docs, something might have been missed:  https://docs.arnoldrenderer.com/display/A5AFHUG/Motion+Blur
