only one point from neibourhood and has maxmum ptNum from them.(VOP)
saca
hi, i have a question.
does PointCloudOpen get some points?(parameter:Number of points > 1)
can i get only one point has maxmum ptNum from them ?
the point is 'c5' in this image.
points on circle c0~c5
points on line L0~02
the line position is center of the circle.
distance from L0~L2 to c0~c5 is same.
thanks.
Nearest_MaxPtNum_v001.001.hip
Hi, I am not skilled in vops, but here is the vex code, and file is attached.
The principle is:
For each found point (pciterate, while loop), you pcimport the point.number, and set this point.number to the "max_ptnum" attrib, only if currently iterated point.number is bigger than what is already stored in this attrib (all previously found point.numbers). At the end, you should have max_ptnum of all the found points.
In the Set Attribute VOP, it is called Merge Mode: Maxiumum
string Pchannel  = "P";
vector P         = @P;
float  radius    = 10.0;   // search within this radius
int    input     = 1;      // search in this input
int    maxpoints = npoints(1);
int    handle    = pcopen(input, Pchannel, P, radius, maxpoints);
while( pciterate(handle) == 1 )
    int found_ptnum;
    pcimport(handle, "point.number", found_ptnum);
    // next line stores the found_ptnum, only if it is bigger then previously found
    setpointattrib(0, "max_ptnum", @ptnum, found_ptnum, "max");
pcclose(handle);
Nearest_MaxPtNum_v001.001_VEX.hiplc
