Compiling With Windows
im actualy new to the houdini programming stuff, and tried to run the compiler directly from Visual Studio (as i do normaly), but that doesnt work out very well. So i used one batchfile i found,
 hcustom  POP_FrequenzTest.C -I h:\_dev\_libraries\blitz -L h:\_dev\_libraries\blitz
which actualy worked quite well even with other .h & .cpp files which i use for other classes but actualy i got a stupid "unresolved Symbol" message where definitly no every symbol is in place *G*.
So i thought maybe i have to add the other .cpp file to the compiler to get it work.
 hcustom  hou_helper.cpp  POP_FrequenzTest.C -I h:\_dev\_libraries\blitz -L h:\_dev\_libraries\blitz
maybe i dont know, im not realy familar with commandline compiling, seems that i'm screwed without visual studio :blink: . thx for your help
Infernalspawn
i've read all the stuff but that doesnt realy help me :-(, i guess this is a more general problem not a special houdini question. how do i have to compile an dso/dll without a makefile especialy when i have multiple classes and for every class a seperate cpp/h file ?
pleasssssssssseee help ;-)
thx
Infernal
yehaaa, hust did it.
there are to ways to compile mutliple classes with hCustom wint windows.
1) Easy Way
Including CPP Files Instead of H files in your Operator C - File
and just compile your Operator C File
2) elegant Way
Compile everything seperatey and link everything by hand, beware of the dependencies
hcustom  hou_intVector.cpp
hcustom  hou_helper.cpp		   -l hou_intVector.o
hcustom  hou_gridCube.cpp	-l hou_intVector.o -l hou_helper.o
hcustom  hou_grid.cpp		-l hou_intVector.o -l hou_helper.o -l hou_gridCube.o
hcustom  POP_myPOP			-l hou_intVector.o -l hou_helper.o -l hou_gridCube.o -l hou_grid.o
Problem is, everytime you call hcustom it creates a dll file in your dso directory even from the files which are not operators. you still have to delete them
ok maybe it helps somebody
greez Sebastian
Personally, I would suggest learning how to use makefiles. If you must, there's even an semi-complete nmake file for MSVC provided in $HFS/toolkit/makefiles. Failing that, you can always just make a new project and copy over the compiler/linker options. But I'll refrain from giving step by step instructions because this is really the domain of reading the MSVC (or MSDN) documentation.
