Pyro Candle Artifact At the top end of BBox
gang
Very hard to guess without seeing at least a simple example showing what you are doing - always a good idea to include something, even a proxy setup, to get a better response for help.  As a random guess, if the top/+Y of your container is closed perhaps temperature is accumulating and being fed into the shading
  • 2 weeks later...
1 minute ago, bunker said:
I had the same issue with my viewport before. is that a flipbook?
Yes, this is flipbook. Do you mean this is only a viewport issue?
