Dr. Gore Posted October 9, 2006 Share Posted October 9, 2006 I been using Softimage XSI for freelance projects and I have been putting Houdini on hold, but I'm just now getting back in to it. I want to model as fast as in XSI, but in Houdini. Is the hotkey L the only Loop oriented key function. I can't seem to select edge rings with using the edit op. Is there a node workflow for consistly using edgeloop in Houdini. Quote Link to comment Share on other sites More sharing options...
Jason Posted October 9, 2006 Share Posted October 9, 2006 I been using Softimage XSI for freelance projects and I have been putting Houdini on hold, but I'm just now getting back in to it. I want to model as fast as in XSI, but in Houdini. Is the hotkey L the only Loop oriented key function. I can't seem to select edge rings with using the edit op. Is there a node workflow for consistly using edgeloop in Houdini. I'm no modeler but I know that if you hit "2" in the viewport to go to Edge selection mode, "f", "r" and "l" and "L" are available for edge-loop operations. The same keys in Points selection mode ("1") will allow point walking. Hope this helps at all, Jason Quote Link to comment Share on other sites More sharing options...
khasperha Posted October 9, 2006 Share Posted October 9, 2006 hey Dr. Gore you can read the help section too khasperha Quote Link to comment Share on other sites More sharing options...
Dr. Gore Posted October 9, 2006 Author Share Posted October 9, 2006 Thanks for the help Jason. Everything (F,L,and R) works but the hotkey "I" what edge is it selecting. I can't get "I" to do anything. Quote Link to comment Share on other sites More sharing options...
Jason Posted October 9, 2006 Share Posted October 9, 2006 Thanks for the help Jason. Everything (F,L,and R) works but the hotkey "I" what edge is it selecting. I can't get "I" to do anything. Actually I was thinking about the lower-case L Quote Link to comment Share on other sites More sharing options...
