Deleting outside primitives after boolean fracture
Trilec
hi all,
This is a bread and butter problem, solved in many different ways....remove (cull) the outside piece primitives after a "Boolean Fracture".
Ive been looking for a simple and fast VEX solution (not... for-each loop nodes)
I found one that seems in the right direction as I love its simplicity. (was trying this in detail mode)
If anyone has other or a more elegant VEX solution I would love to explore it, cheers
int insides [] = expandprimgroup(0, "inside");
int outsides[] = expandprimgroup(0, "outside");
foreach(int inside; insides)
    int     success;
    string  insideName = primattrib(0, "name", inside, success);
    foreach(int outside; outsides)
        string outsideName = primattrib(0, "name", outside, success);
        if(insideName == outsideName)
            setprimgroup(0, "inside", inside, 0, "set");
            setprimgroup(0, "outside", inside, 1, "set");
            setprimattrib(0,"Cd",outside,set(1,0,0),"set"); //small test using the colour
            break;
as usual any help appreciated.
Edited by Trilec
hilighted booleans as this is the main issue,
Thanks Flcc,
Interesting, uses similar to above, by default if you turn the Material type from Concrete to Wood (boolean fracture) you need to change the group expand to "wood_cutoutside".
im still investigating and will post any other VEX solutions I might find.
c
Edited by Trilec
