[Solved] HDA loading incomplete in UE4
sant0s81
Hey,
I know, its a topic that was talked about alot.
But I have no idea whats going on.
I installed the newest Houdini Indie version (18.0.499) and even tried the daily version.
The Unreal Engine is also the most up to date version (4.25.1).
From the change logs I understood, that 18.0.499 and UE 4.25.1 should work together.
I made a very simple HDA with just a box and tried to load it into UE. (attached)
But I only get the temp Houdini Logo geo that shows when importing an HDA.
So I tried an asset from orbolt, same problem.
Than I tried an HDA from a mate that was made with HoudiniFX.
That asset actually will crash in Houdini, but loads incomplete into UE.
I only see the cannon pipe, but the rest like the wheels etc do not load.
That gave me the idea, that the plugin works but something else is not working.
I also realised, that every time I run UE, it will tell me, that there is a new Plugin - it points me to the Houdini Engine Plugin (shows under the tab "Renderer" ?)
Under Project Settings the Houdini Engine is listed.
I also tried an older Version of UE.
I also checkt if maybe the firewall is blocking something.
Could there be something else, that makes problems?
Everything is lega, so no cracked Houdini running or whatever.
But still, I have no idea whats going on.
I am also in contact with Support - but I guess I am doing something wrong somewhere.
Does anybody have an idea, what could be the problem?
Thanks and sry to ask about that topic again, but makes no sense to me. :)
sant0s
sant0s_box_xyz.hdalc
Edited by sant0s81
