Azimuth7 Posted July 9, 2020 Share Posted July 9, 2020 Dear friends I´m a new Houdini user and I´m trying to do something different from most of the sand sims. I have a thread of sand falling from the hole of an hourglass, and I´m trying to do build a sand object as the sand falls on the container bellow the hole. The question is, how can I direct my sand particles to become the object that I want? Any suggestions would be appreciated. Thanks in advance Quote Link to comment Share on other sites More sharing options...
ryew Posted July 9, 2020 Share Posted July 9, 2020 It is always best to post even a simple example file demonstrating what you have tried to do so people can see where your setup logic might be modified or improved for the result you are after Quote Link to comment Share on other sites More sharing options...
Azimuth7 Posted July 10, 2020 Author Share Posted July 10, 2020 Sure... something like that, but forming the skeleton with the sand particles that fall... Quote Link to comment Share on other sites More sharing options...
Librarian Posted July 10, 2020 Share Posted July 10, 2020 https://www.sidefx.com/tutorials/sad-clock-grain-simulation/ Quote Link to comment Share on other sites More sharing options...
Azimuth7 Posted July 10, 2020 Author Share Posted July 10, 2020 Thanks I´ve seen this tutorial before, but what I want to do is quite the opposite. I want to make the sand falls, and fill a geometry. I was trying to do that with grains. I was able to make the sand falls on the hourglass, but I´m trying to use pop attract with grains to attract the grains to the scatter points of the geometry and stick to it, and it´s not working :-( Quote Link to comment Share on other sites More sharing options...
Lourcloud Posted July 13, 2020 Share Posted July 13, 2020 Hey, I'm new too btw. A simple workaround until someone more experienced comments is that you could make one sim only falling, and another grain object that is frozen, essentially achieving the same effect? Quote Link to comment Share on other sites More sharing options...
Azimuth7 Posted July 16, 2020 Author Share Posted July 16, 2020 Indeed you can. I solved the problem using pop attract and making the grains sticking to my geo. But thanks! Quote Link to comment Share on other sites More sharing options...
