fracture Piece min max values of the local cut
Trilec
Hi All, sorry for the heading, Its a hard one to describe lol.
I have a booleanfracture piece and want to process only the middle points , then with that create geo that knows the distance to top and bottom of its local position
(as the slice fracture is not a flat plane, hopefully a picture helps).
Im not sure the best approach, I would start with nearpoints in some way ,finding the top points and test down for a middle storing the lowest for distance checks??
lol, well its a tricky one
Edited by Trilec
updated graphics
Hi Noobini, Thanks for the reply.
I simply would like an understanding if im on the right approach, a jpg concept would also be great ;) ,
The script is a simple booleanfracture piece ,nothing special, my feeling was its a quite advanced topic and those who would understand the issue would not need such a thing, perhaps one of the long term members can post if this the correct assumption?
cheers
thanks noobini,
This is a useful node, whats nice is its really just VEX code wrapped in a nice package for selection.
seems the approach in VEX with nearpoints  is still on the cards but the relbox code is clean;
abs( (relbbox(0,@P).y)-0.5)<ch("spread")
However this does depend on the rebbox alignment, unfortunate this fails as the bbox is world aligned and if a cut is on an angle it fails
the GroupCreate (include by edge) will find the top /bottom so perhaps processing this after might help...
Ill still investigate further...
thanks again for the jpg, sorry you did not get a hip file...next time :)
cheers
Edited by Trilec
spelling
