Redshift compatibility
Hello guys. I have a question related to the builds. Can Houdini 18 run a redhift build for Houdini 17.5? Because I am still thinking on jumping to Houdini 18 but it depends on this subject.
Thanks for your time.
Edited by pizola
You can find these informations in release_note.txt in the redshift folder (C://appdata/redshift).
But no you can't use a build for H17 with H18. And due to the frequent build of houdini, support for old redshift version are quickly dropped.
Non supported version can work or not.
Thanks for the fast response
