Masoud Posted August 2, 2020 Share Posted August 2, 2020 Hi; I tried to make some animation using CHOPs based on a tutorial from "Peter Quint" (https://www.youtube.com/watch?v=4tGCG5u1jwI), but I got some problems with the rotation, so as you can see in the image below, my box rotation jumps on some frames, and it's starting rotation is wrong! How can I fix it? Thanks for helping. CHOPs animation_01.hip Quote Link to comment Share on other sites More sharing options...
eimk Posted August 2, 2020 Share Posted August 2, 2020 This seems to be a problem with the normals. If you add normals to the points with a normal or polyframe node before the copy to points they won't jump. Quote Link to comment Share on other sites More sharing options...
