[SOLVED] Displacement mask in shader
Hi !
I'm trying to replicate this tutorial :
But i'm having trouble applying the displacement in the shader. It seems the tutorial was made with an older version of houdini and things have changed quite a bit since then.
I managed to import the mask attribute in the shader but i'm stuck as to where should i put it.
I did manage to do the displacement at SOP level but i'm lost in shader level...
Any pointers ?
Cheers !
pyrite.hipnc
Edited by LunarB
If you open up the Principled Shader with "Allow Editing of Contents", you have to look for a node called "displace1". The "scale" input of that node is where you put your mask. "Shift+7" shortcut will allow you to search for a node by name and highlight it.
