Skin SOP, shift pairing
AntoineSfx
I have a curve, which I modify with edits and resamples. I later merge it with the original geometry, and skin the result.
How can I shift the points in a curve to affect how Skin SOP pairs points ? I tried Sort SOP/shift but Skin SOP doesn't seem to use that information.
It's using the same point order as in Carve SO, so I think it's related to how a polygon is uv parametrized internally, so I'm looking for a way to shift that..
As far as I know, you can't shift or change the parametric coordinates of a primitive. You can try to play with a convert sop (convert the curve to mesh and play with the parameters) before skinning, but it's only to sample more or less points on the u and v of the curve to add more division to the skinned mesh. If you find how to shift the parametric of a curve let me know !
