davidyannick Posted August 14, 2020 Share Posted August 14, 2020 At the top of my network I made a vop to set Normal, afetr the solver normals are no more here any idea how to solve this ? Thanks for your help vellum solver normal.hiplc Quote Link to comment Share on other sites More sharing options...
Noobini Posted August 14, 2020 Share Posted August 14, 2020 if you rclick on the vellumsolver allow editing, dive in, near the top there's the culprit Remove all normals, disable it. WHY is it there ? dunno. if you didn't use the vellumsolver SOP and use shelf tool...when it imports data back from DOP it deletes the normal as well...there must be a reason...to clean up the file to make it lighter ? it's 'just' an N...sounds implausible but I don't know. Quote Link to comment Share on other sites More sharing options...
eimk Posted August 15, 2020 Share Posted August 15, 2020 It might be because vellum deforms geometry, so any normals set before the solver aren't going to be accurate afterwards. Still seems like something that should have a toggle. Quote Link to comment Share on other sites More sharing options...
