intersect function problem
isah_voodoo
hello,
I put together a quick test file with a simple line intersecting a grid. My goal is to figure out which primitive the line is intersecting on the grid and then delete those primitives. I wanted to do this with the intersect function.
 I managed to get it working however when I try and move my line around with a transform before it goes into the wrangle, it stops working. I have no idea why this is happening because my lines are always intersecting the grid so there should always be primitives being deleted.
If you enable "transform3" in my file, you will see what i mean.
Thank you.
intersect_vex.hipnc
