array and foreach question
isah_voodoo
Hello again,
I have a quick question about arrays and foreach using vex
if I have a line like this:
i[]@pts= primpoints(0, @primnum);
for(int i=0; i<len(@pts); i++){
    v@pos = point(0, "P", @pts);
So this is basically getting the current point position of each point in the array and storing it in v@pos.
My question is , what is the difference between  v@pos = point(0, "P", @pts);    VS.     v@pos = point(0, "P", i);
This would still be doing the same thing correct? Is it better practice to do do @pts instead of just i ?
Thanks
Edited by isah_voodoo
You're doing it it wrong. There is two ways to iterate over an array :
vector myarray[];
foreach(int pt; myarray)
	vector pos = point(0, "P", pt);
//or
for(int i = 0; i < len(myarray); i++)
	vector pos = point(0, "P", myarray[i]);
In your code, you need to pass i as the index of the item you want in your array. Here, you're passing the whole array without specifying an index.
//it's more convenient to assign primpoints to a local variable instead of an attribute
for(int i = 0; i < len(@pts); i++)
    v@pos = point(0, "P", [i]@pts);
Cheers,
  On 9/1/2020 at 12:35 AM, isah_voodoo said:
@DonRomano Thanks for the reply. Did you mean to write:
v@pos = point(0, "P", @pts[i]);
instead of:
but if I write:
Isn't this also iterating through each index of all the arrays in the for loop ?
Thanks
Expand
v@pos = point(0, "P", i); returns the position of the point i, instead of the point at the index i of your point arrays. Use i as an array index, not as a point number.
https://www.sidefx.com/docs/houdini/vex/arrays.html
