Librarian Posted May 15, 2021 Author Share Posted May 15, 2021 in this order int dim = sqrt(@numelem); vector pos = set(@elemnum%dim,@elemnum/dim)/(dim-1); float point_spacing = 1.0/(dim-1) + 0.00001; pos -= {0.5,0.5}; if (length(pos)*2<0.9*noise(pos*5.1)*@Time){ int pt = addpoint(0,pos); setpointattrib(0,"pt_sp",pt,point_spacing); } int near_pts[] = pcfind(0,"P",@P,@pt_sp,999); if (len(near_pts)<chi("fate")) @Cd = hsvtorgb(dot(@P,{1,1,1}),1,1); else @Cd = {0,0.1,0}; vector pos = @P; i@class = pcfind (1,"P",pos,1000,2)[0]; @Cd = rand(@class); int pts[] = pcfind(0,"P",@P,@pt_sp,999); i[]@pt= pts; int near_pts; int class; foreach(int pt; pts){ int bool = @class == point(0,"class",pt); if(bool) near_pts++; } if(near_pts<chi("fate")) @P.z += 0.001*@class+0.3; else @Cd ={0,0.1,0}; int pts[] = pcfind(0,"P",@P,@pt_sp+ch("r"),999); i[]@pt= pts; int near_pts; int class; foreach(int pt; pts){ int bool = @class == point(0,"class",pt); if(bool) near_pts++; } if(near_pts<chi("fate")) @P.x -= 0.7; //@P.z += 0.001*@class+0.1; else {@P.x -=1.4;} int pts[] = pcfind(0,"P",@P,@pt_sp,999); i[]@pt= pts; int near_pts; int class; foreach(int pt; pts){ int bool = @class == point(0,"class",pt); if(bool) near_pts++; } if(@P.z == 0 && near_pts<chi("fate")){ @P.z += 0.1; @Cd = {1,0,0}; } else if(@P.z == 0.1) @Cd = rand (@class); foreach int pts[] = pcfind(0,"P",@P,@pt_sp,999); i[]@pt = pts; int near_pts; int class; foreach(int pt; pts){ int bool = @class == point(0,"class",pt); if(bool) near_pts++; } float u =float(detail(1,"iteration"))/(detail(1,"numiterations")-1); if(@P.z == 0 && near_pts<chi("fate")){ @Cd = rand(@class); @P.z += 0.1*chramp("ramp",u); } Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 15, 2021 Author Share Posted May 15, 2021 cut any dir string in0 = @OpInput1; int nprims = nprimitives(in0); int op; string operation = chs("keep"); if(operation == "above")op= 1; if(operation == "below")op= 2; else op= 0; vector cutDir = normalize(chv("cutDir")); vector cutOrigin = chv("cutOrigin"); float dist = ch("dist"); ////////////////////////////////////////////////////////////////// for(int primnum = 0; primnum < nprims; primnum++) { int vers[] = primvertices(0, primnum); int length = len(vers); int border=0; int prim0pts[]; int prim1pts[]; int numNewPts = 0; // check if this mesh is split for(int i = 0; i< length; i++) { int srcPoint = vertexpoint(in0, vers[i]); vector srcP = point(in0, "P", srcPoint); vector srcPDir = normalize(srcP - cutOrigin); float dot = dot(cutDir, srcPDir); if(dot<=0)border += 1; } // if it is not cut, maybe remove and done. if(border == 0) { if(op == 2)removeprim(geoself(),primnum,1); // continue;continue; } else if(border == length) { if(op == 1)removeprim(geoself(),primnum,1); //continue; } else { // cut mesh int srcPoint; float srcDot; for(int i = 0; i< length; i++) { int hedge = vertexhedge(in0, vers[i]); //int primary = hedge_isprimary(in0, hedge); //if(primary == 0)continue; int destVtx = hedge_dstvertex(in0, hedge); srcPoint = vertexpoint(in0, vers[i]); int destPoint = vertexpoint(in0, destVtx); vector srcP = point(in0, "P", srcPoint); vector destP = point(in0, "P", destPoint); vector srcPDir = normalize(srcP - cutOrigin); vector destPDir = normalize(destP - cutOrigin); srcDot = dot(cutDir, srcPDir); float destDot = dot(cutDir, destPDir); if(srcDot > 0) { push(prim0pts, srcPoint); } else if(srcDot == 0) { push(prim0pts, srcPoint); push(prim1pts, srcPoint); } else if(srcDot < 0) { push(prim1pts, srcPoint); } if((sign(srcDot) != sign(destDot)) && srcDot != 0 && destDot != 0) { //@Cd=set(float(i)/length, float(border)/length, 0); float bias = -destDot/(srcDot - destDot); int newPt = addpoint(geoself(), lerp(destP, srcP, bias)); push(prim0pts, newPt); push(prim1pts, newPt); numNewPts += 1; } } // remove original mesh, and add 2 meshes which cover original removeprim(geoself(),primnum,1); if(op != 2) { int newPrim = addprim(geoself(), "poly"); foreach(int pt; prim0pts) { addvertex(geoself(), newPrim, pt); } } if(op != 1) { int newPrim = addprim(geoself(), "poly"); foreach(int pt; prim1pts) { addvertex(geoself(), newPrim, pt); } } } } alpha+info e90.hiplc Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 17, 2021 Author Share Posted May 17, 2021 have Fun SCFiOSC.hiplc Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 27, 2021 Author Share Posted May 27, 2021 Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 11, 2021 Author Share Posted June 11, 2021 Thanx Asia Students. Breaking and endless possibility .. Dot_PictureTOPNET.hipnc Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 26, 2021 Author Share Posted June 26, 2021 thanx To Asia Forums Hm How to make this In Vex???? from math import cos,sin geo = hou.pwd().geometry() poly = geo.createPolygon() for i in range (36): t = -6.2*i/36.0 p = cos(t),sin(t),0 point = geo.createPoint() point.setPosition(p) poly.addVertex(point) dim = 30 bbx= poly.boundingBox() min= bbx.minvec() max = bbx.maxvec() for point in poly.points(): p = point.position() p[0]=hou.hmath.fit(p[0],min[0],max[0],3,dim-3) p[1]=hou.hmath.fit(p[1],min[1],max[1],3,dim-3) p[2]-=0.1 point.setPosition(p) group_inside = geo.createPointGroup('inside') group_outside=geo.createPointGroup('outside') group_all = geo.createPointGroup('all',1) for i in range(dim*dim): index = hou.Vector3(i%dim,i/dim,0) point = geo.createPoint() point.setPosition(index) group_all.add(point) dir = hou.Vector3(0,0,-1) pos_out = hou.Vector3() normal_out = hou.Vector3() uvw_out = hou.Vector3() inside=geo.intersect(index,dir,pos_out,normal_out,uvw_out) if(inside+1): group_inside.add(point) else: group_outside.add(point) def extend(point,dist): points = [] dist = int(dist) p = point.position() ori = p-hou.Vector3(dist,dist,0) dim0 =1+2*dist n = int(dim0*dim0) for i in range(n): p= ori+hou.Vector3(i%dim0,i/dim0,0) num= int(p[1]*dim+p[0]) points.append(group_all.iterPoints()[num]) return points geo.addAttrib(hou.attribType.Point,'Cd',(1.0,1.0,1.0)) point= geo.point(500) dist= hou.frame() points=extend(point,dist) for point in points: point.setAttribValue('Cd',(1.0,0,0)) #groups group = geo.createPrimGroup('group') lim_n0 = 100 for i in range(lim_n0): outside_points = set(group_outside.points()) max_dist = 0 point0 = group_inside.iterPoints()[0] for point in group_inside.points(): lim_n=20 for i in range(lim_n): points = set(extend(point,i)) if(len(points & outside_points)): dist=i-1 break if max_dist<dist: max_dist = dist point0 = point pos = point0.position() val = hou.Vector3(0.5,0.5,0) max_dist += 0.5 p0 = pos+hou.Vector3(-max_dist,-max_dist,1) p1 = pos+hou.Vector3(-max_dist,+max_dist,1) p2 = pos+hou.Vector3(max_dist,max_dist,1) p3 = pos+hou.Vector3(max_dist,-max_dist,1) points=geo.createPoints([p0,p1,p2,p3]) polys=geo.createPolygons([points,]) group.add(polys) points=extend(point0,max_dist) group_outside.add(points) group_inside.remove(points) if len(group_inside.points())==0:break Quote Link to comment Share on other sites More sharing options...
Librarian Posted July 3, 2021 Author Share Posted July 3, 2021 (edited) Chops micro Edited July 3, 2021 by Librarian close up Quote Link to comment Share on other sites More sharing options...
Librarian Posted July 18, 2021 Author Share Posted July 18, 2021 Maybe useful Vex ....Wiggle ---prim offset extrude pluss pluss VexC.hiplc Quote Link to comment Share on other sites More sharing options...
Librarian Posted August 7, 2021 Author Share Posted August 7, 2021 Some Vex before block setdetailattrib(0,"center",@P/@numpt,"add"); prim float area = primintrinsic(0,"measuredarea",@primnum); if(area>ch("min_area")){ vector center =detail(0,"center"); float k = relbbox(@P).x; float bias = 0.5*smooth(0,0.5,k-1+@Time*ch("speed"),ch("rolloff")); vector ps[]; vector new_ps[]; for (int vtx=0;vtx<@numvtx;vtx++){ int pt0= primpoint(0,@primnum,vtx); vector pos0= point(0,"P",pt0); append(ps,pos0); int pt1 = primpoint(0,@primnum,(vtx+1)%@numvtx); vector pos1 = point(0,"P",pt1)-center; removepoint(0,pt0); pos0 -=center; matrix3 rot = slerp(dihedral(pos0,pos0),dihedral(pos0,pos1),bias); pos0 = pos0*rot; vector primcenter = normalize(@P-center)*length(pos0-center); rot = slerp(dihedral(pos0,pos0),dihedral(pos0,primcenter),ch("s")*sin(PI*2*bias)); pos0= pos0*rot+center; int pt3 = addpoint(0,pos0); setvertexpoint(0,@primnnum,vtx,pt3); append(new_ps,pos0); } foreach(int vtx;vector p;new_ps){ int pt0= addpoint(0,ps[vtx]); int pt1= addpoint(0,new_ps[vtx]); int pt2 =addpoint(0,new_ps[(vtx-1)%@numvtx]); int prim0 = addprim(0,"poly",pt0,pt1,pt2); setprimattrib(0,"Cd",prim0,{1,0,0}); if(1){ pt0 = addpoint(0,ps[vtx]); pt1 = addpoint(0,new_ps[vtx]); int pt3 = addpoint(0,ps[(vtx+1)%@numvtx]); prim0 = addprim(0,"poly",pt3,pt1,pt0); setprimattrib(0,"Cd",prim0,{0,1,0}); } } @Cd = { 0,0,1}; } Quote Link to comment Share on other sites More sharing options...
Librarian Posted August 27, 2021 Author Share Posted August 27, 2021 (edited) Nice to Have ...maybe useful for someone Edited August 27, 2021 by Librarian Quote Link to comment Share on other sites More sharing options...
Librarian Posted August 28, 2021 Author Share Posted August 28, 2021 (edited) combining with fuicolors file chops <----> Cops and Mantra. 'Cop Snippet' float roughness = rough; float VanDerCorpus(int n; int base) { float invBase = 1.0f / float(base); float denom = 1.0f; float result = 0.0f; for(int i = 0; i < 32; ++i) { if(n > 0) { denom = float(n) % 2.0f; result += denom * invBase; invBase = invBase / 2.0f; n = int(float(n) / 2.0f); } } return result; } // ---------------------------------------------------------------------------- // ---------------------------------------------------------------------------- vector2 HammersleyNoBitOps(int i; int N) { return set(float(i)/float(N), VanDerCorpus(i, 2)); } vector ImportanceSampleGGX(vector2 Xi;vector N;float roughness) { float a = roughness*roughness; float phi = 2.0 * PI * Xi.x; float cosTheta = sqrt((1.0 - Xi.y) / (1.0 + (a*a - 1.0) * Xi.y)); float sinTheta = sqrt(1.0 - cosTheta*cosTheta); // from spherical coordinates to cartesian coordinates vector H; H.x = cos(phi) * sinTheta; H.y = sin(phi) * sinTheta; H.z = cosTheta; // from tangent-space vector to world-space sample vector vector up = abs(N.z) < 0.999 ? set(0.0, 0.0, 1.0) : set(1.0, 0.0, 0.0); vector tangent = normalize(cross(up, N)); vector bitangent = cross(N, tangent); vector sampleVec = tangent * H.x + bitangent * H.y + N * H.z; return normalize(sampleVec); } vector sampleSphere(vector dir; string img){ float phi = atan2(dir.x, dir.z); float theta = acos(dir.y); float u = phi / (2.000 *PI ); float v = 1 - theta / PI; //u = clamp(u,0,1); //v = clamp(v,0,1); vector imgL = texture(img,u,v); return imgL; } int SAMPLE_COUNT = count; vector N = normalize(localPos); vector R = N; vector V = R; float totalWeight = 0.0; vector prefilteredColor = 0.0; for(int i = 0; i < SAMPLE_COUNT; ++i) { int testi = i; vector2 xy = HammersleyNoBitOps(testi,SAMPLE_COUNT); vector H = ImportanceSampleGGX(xy, N, roughness*roughness); vector L = normalize(2.0 * dot(V, H) * H - V); float NdotL = max(dot(N, L), 0.0); if(NdotL > 0.0) { prefilteredColor += sampleSphere(L,map) * NdotL; totalWeight += NdotL; } } prefilteredColor = prefilteredColor / totalWeight; color = prefilteredColor; Edited August 28, 2021 by Librarian 2 Quote Link to comment Share on other sites More sharing options...
Librarian Posted September 8, 2021 Author Share Posted September 8, 2021 it can be useful Fun05.hiplc 1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted November 14, 2021 Author Share Posted November 14, 2021 Have Fun. Wak ASCIIFluid.hiplc 1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted November 14, 2021 Author Share Posted November 14, 2021 Have Fun. Asia Lady GB.hiplc Quote Link to comment Share on other sites More sharing options...
Librarian Posted November 20, 2021 Author Share Posted November 20, 2021 from beauty Of Asia @thu Thanx ..Volume Domain Wrapping. function vector gumbelDistribution(vector v) { return -log(-log(v)); } // return 0 ~ 1 function vector selectedNoise(int noiseId; vector pos; float time; float flow) { int Random = 0, // random PerlinNoise = 1, // noise OriginalPerlinNoise = 2, // onoise SimplexNoise = 3, // xnoise SparseConvolutionNoise = 4, // snoise FlowNoise = 5, // flownoise CurlNoise = 6, // curlnoise ArigatorNoise = 7, // anoise WorleyNoise = 8, ManhattanDistWorleyNoise = 9, ChebyshevDistWorleyNoise = 10; if(Random == noiseId) {// 0 ~ 1 return random(set(pos.x, pos.y, pos.z, time)); } if(PerlinNoise == noiseId) { // 0 ~ 1 return noise(set(pos.x, pos.y, pos.z, time)); } if(OriginalPerlinNoise == noiseId) { // 0 ~ 1 error("Error: OriginalPerlinNoise"); } if(SimplexNoise == noiseId) { // 0 ~ 1 return xnoise(set(pos.x, pos.y, pos.z, time)); } if(SparseConvolutionNoise == noiseId) { // -1.7 ~ 1.7 return snoise(pos); } if(FlowNoise == noiseId) { // 0 ~ 1 (0.2 ~ 0.8), args(p, flow(0 ~ 1)) return flownoise(set(pos.x, pos.y, pos.z, time), flow); } if(CurlNoise == noiseId) { // -1 ~ 1.02 return curlxnoise(set(pos.x, pos.y, pos.z, time)); } if(ArigatorNoise == noiseId) { // anoise 0 ~ 1 // return anoise(pos); vector4 p = set(pos.x, pos.y, pos.z, time); return anoise(pos, 0, noise(p), noise(p) ); } if(WorleyNoise == noiseId) { vector4 p = set(pos.x, pos.y, pos.z, time); int seed; float dist1, dist2, dist3, dist4; wnoise(p, seed, dist1, dist2, dist3, dist4); return set(dist1, dist2, dist3); } if(ManhattanDistWorleyNoise == noiseId) { vector4 p = set(pos.x, pos.y, pos.z, time); int seed; float dist1, dist2, dist3, dist4; mwnoise(p, seed, dist1, dist2, dist3, dist4); return set(dist1, dist2, dist3); } if(ChebyshevDistWorleyNoise == noiseId) { vector4 p = set(pos.x, pos.y, pos.z, time); int seed; float dist1, dist2, dist3, dist4; cwnoise(p, seed, dist1, dist2, dist3, dist4); return set(dist1, dist2, dist3); } error("Error: selected"); } function vector fitTo01(int noiseId; vector vec) { int OriginalPerlinNoise = 2, // onoise SparseConvolutionNoise = 4, // snoise CurlNoise = 6; // curlnoise // -1 ~ 1 if(OriginalPerlinNoise == noiseId) return fit11(vec, {0,0,0}, {1,1,1}); // -1.7 ~ 1.7 if(SparseConvolutionNoise == noiseId) return fit(vec, {-1.7, -1.7, -1.7}, {1.7, 1.7, 1.7}, {0,0,0}, {1,1,1}); // -1 ~ 1.02 if(CurlNoise == noiseId) return fit(vec, {-1, -1, -1}, {1.02, 1.02, 1.02}, {0,0,0}, {1,1,1}); return vec; // 0 ~ 1 } function vector sampling(int fbmId; vector v) { int Normal = 1, Cauchy = 2, Sphere_Uniform = 3, Orientation_Uniform = 4, GumbelDistribution = 5; int samplingId = chi("fbm" + itoa(fbmId) + "_SamplingID"); if (samplingId == Normal) { vector vec = fitTo01(chi("fbm" + itoa(fbmId) + "_NoiseID"), v); return sample_normal(vec); } if (samplingId == Cauchy) { vector vec = fitTo01(chi("fbm" + itoa(fbmId) + "_NoiseID"), v); return sample_cauchy(vec);// -1 ~ 0 ~ 1 } if (samplingId == Sphere_Uniform) { vector vec = fitTo01(chi("fbm" + itoa(fbmId) + "_NoiseID"), v); return sample_sphere_uniform(vec); } if (samplingId == Orientation_Uniform) { vector vec = fitTo01(chi("fbm" + itoa(fbmId) + "_NoiseID"), v); return sample_orientation_uniform(vec); } if (samplingId == GumbelDistribution) { vector vec = fitTo01(chi("fbm" + itoa(fbmId) + "_NoiseID"), v); return gumbelDistribution(vec); } error("ERROR: Sampling"); } function vector fitTo11(int noiseId, samplingId; vector v) { int notSelectedSamplingId = 0; if(samplingId == notSelectedSamplingId) { int OriginalPerlinNoise = 2, // onoise SparseConvolutionNoise = 4, // snoise CurlNoise = 6; // curlnoise if( (OriginalPerlinNoise != noiseId) && (SparseConvolutionNoise != noiseId) && (CurlNoise != noiseId) ) { return fit01(v, {-1,-1,-1}, {1,1,1}); } } } function vector fbm(int octave; int noiseId; vector p; vector sft; float t; float angle; float flow) { vector pos = p; vector v = {0}; vector a = {0.5, 0.5, 0.5}; matrix mat = ident(); // float radius = 3.1415; float time = t; // float scale = 2; vector shift = sft; for (int i = 0; i < octave; ++i) { v += a * selectedNoise(noiseId, pos, time, flow); //TODO: rotate parameter rotate(mat, radians(angle), {0,1,0}); pos = mat * pos * {2,2,2} + shift; a *= 0.5; } return v / (1 - a); } function vector domainWarping(vector p; float time) { vector pos = p * chf("Scale"); // FBM 1 ------------------------------------------ vector fbm1 = fbm( chi("fbm1_Octave"), chi("fbm1_NoiseID"), pos, chv("fbm1_Shift"), time, chf("fbm1_Angle"), chf("fbm1_FlowNoise_Flow") ); if (chi("fbm1_SamplingID") != 0) { fbm1 = sampling(1, fbm1); } fbm1 *= chv("fbm1_Scale") * chf("fbm1_Uniform_Scale"); // return fbm1; //debug; // FBM 2 ------------------------------------------ vector fbm2 = fbm( chi("fbm2_Octave"), chi("fbm2_NoiseID"), pos + fbm1, chv("fbm2_Shift"), time, chf("fbm2_Angle"), chf("fbm2_FlowNoise_Flow") ); if (chi("fbm2_SamplingID") != 0) { fbm2 = sampling(2, fbm2); } fbm2 *= chv("fbm2_Scale") * chf("fbm2_Uniform_Scale"); // FBM 3 ------------------------------------------ vector fbm3 = fbm( chi("fbm3_Octave"), chi("fbm3_NoiseID"), pos * (chv("fbm3_Scale") * chf("fbm3_Uniform_Scale")) + fbm2, chv("fbm3_Shift"), time, chf("fbm3_Angle"), chf("fbm3_FlowNoise_Flow") ); if (chi("fbm3_SamplingID") != 0) { fbm3 = sampling(3, fbm3); } if(chi("is_Fit_11")) { fbm3 = fitTo11(chi("fbm3_NoiseID"), chi("fbm3_SamplingID"), fbm3); } return fbm3; } if(chi("is_Density_Attribute")) f@density = domainWarping(v@P, chf("Time")); if(chi("is_Velocity_Attribute")) v@velocity = domainWarping(v@P, chf("Time")); Have fun. Quote Link to comment Share on other sites More sharing options...
vinyvince Posted November 20, 2021 Share Posted November 20, 2021 (edited) On 14/11/2021 at 7:23 AM, Librarian said: Have Fun. Wak ASCIIFluid.hiplc ahaha a love for Pixel nostalgic like me , thanks Tesan Edited November 20, 2021 by vinyvince Quote Link to comment Share on other sites More sharing options...
