strange offset with custom active attribute
valorSix
Hello,
Some of my vex code is returning very strange values than what I thought it should be doing. I have this:
i@startframe = floor(fit01(rand(@id*23.4234), 1001, 1050)); // create random start frames
float duration = 15; //duration
f@active = fit(@Frame-@startframe, @startframe, @startframe+duration, 0,1); //create value between start frame + duration
However, my @active value doesn't start between 1001- 1050 as I specified, it instead starts from frames  2001- 2100. WHy is this? Why is it offset 1000 frames ??
would appreciate any help . thank you
active_value_problem.hipnc
shouldn't logic be like this?
int duration = 15; //duration
f@active = fit(@Frame-@startframe, 0, duration, 0,1); //create value between start frame + duration
btw, "active" as a fraction instead of 1...I'm scratching my head...for what purpose ? Shouldn't it be either 0 or 1 ? You can't be 'slightly' pregnant can you?
Edited by Noobini
my 'guess' of what you are trying to do is this:
i@active = @startframe < @Frame && @Frame < @startframe + duration; //active for the duration
so that they all start off as 0...then up to certain frames...predetermined by wrangle create_startframe..they switch on...and remain active for duration....(then naturally switch off)
Edited by Noobini
11 minutes ago, valorSix said:
@Noobini Thanks, your first logic fixed the issue  , but i'm still confused to how my example ended up being offset 1000 frames ?
In my case I needed some float values, not just 1 or 0 but thanks for the example. appreciate it.
well because you offsetted it. the fit will try to fit a value from min/max to new min/new max....so you set the min to @start_frame which say randomly 1025....so if Frame is 1001 say, 1001 - 1025 is negative...this will never fit into your range....until the Frame is 'big' enough..ie when it reached 2000, then 2000 - 1000 something would more likely to give you 1000 something...and hence fit in your range.
Edited by Noobini
@Noobini Not sure i'm following... How do you figure it would only be big enough when it reached Frame 2000 in your example? If the Value that is being fit is a negative number and not within my range than it should return 0. Only when it reaches the range specified (@startframe- @startframe+duration), than I should get the proper fit values of 0-1 .
Thanks
Thanks
well yeah...it is returning 0 correctly isn't ? so say at frame 1500, 1500 - 1021 = 479
min/max = 1021/1036
is 479 in the range 1021 - 1036 ? NO, so it returns 0 correctly...what are you complaining about ?
so as you scrub between 1001 and 1500....it's always 0.............................until Frame is big enough..
ie. as said, YOU introduced the offset from the correct range of 0 - duration as per my fix.
right now, it may be difficult for you to visually see the effect of your offset error because you're using @startframe which is random.
if you use a static offset like this, it's easier to observe the result
f@active = fit(@Frame-@startframe, 300, 300+duration, 0,1); //create value between start frame + duration
You'll see that it is offset by 300 frames
And therefore you would see how my fix works as the offset is 0.
Edited by Noobini
