Change radius of sphere primitive in vex
ianwww
I've created a sphere primitive in vex, using:
centre_pt = addpoint(0, pos);
sphere_prim = addprim(0, 'sphere', centre_pt);
I want to be able to vary its size in the viewport but can't work out how to do it.  When a sphere prim is added using a SOP, the sphere's size can be changed using scale (the Uniform scale slider).  I thought that this vex would therefore do the same thing:
setprimattrib(0, 'scale', sphere_prim, chf('sphere_size'), 'set');
but changing chf('sphere_size') has no effect on the sphere's size. (I've also tried replacing 'scale' with 'radius', and also with 'radx', 'rady' and 'radz'.)
I've found this link cgwiki which explains how to do it for a prim that has multiple points but a sphere prim only has its single central point.
How can I change a sphere prim's size in vex?
