Cone Twist Motor Stops working after 50 frames if animated
sefisec
Having a problem with a Motor in a Cone Twist Relationship for a few days. It's stop working after 50 frames (not generating any torque) if I animate a motor values.
Parameters animated like 0 to 30 to 0 to 45 to 0 to -45 to 0 etc.., so motor should only increment a small angle per timestep.
Tried to modify almost any parameter I could from lowest to highest, no success (apart from Time Scale, but it's not really a solution). Simulation substeps don't have visible effect either.
Minimal working setup in the attached file. Banging my head against this problem for a couple days :(
CT_problem_apprentice.hipnc
Edited by sefisec
