Svg export multiples stroke colors
Sseast
Hello,
I grabbed the svg export python from Antagma tutorial and I used this python to do some laser-cutting.
I would like to upgrade this script by exporting my geometry in 2 different colors so that I can vary the laser power.
I have created an edge group for both the colors I want to export (red/blue) but I don't know how I can distinguish these groups using python, anyone ?
Right now I do 2 differents python export node, but I'd be thrilled if I could do everything in the same node.
Here's my hip if someone want to take a look into_svg.hipnc
Thank you
Edited by Sseast
@Sseast Hi
WREN ROP SOHO ...try .HOPE IT HELPS !!
Recently I build newer config of PC, so can't find mine File that I have.. used for CNC router .for different reason I have used 2 diff splines .I gonna Find Soon
Here you have tutorial with CODES  if you have problem you can translate google.
ex of mine EXPERIMENTOS
