nuki Posted October 15, 2020 Share Posted October 15, 2020 (edited) I have a source vdb and a sparse pyro dopnet, the source being a thresholded noise with only 0.0 or 1.0 values. When enabling "solve on creation frame" I would expect the values of the source and the sim (with all advection disabled) to be the same. As you can see they're not, and I can only suspect the grids of the source and sim volumes are not lining up resulting in interpolated samples. left is a slice of the source, right is a slice of the sim For sake of avoiding interpolation of the values during sourcing, the source volume field should exactly match the sim field (voxel size and positions). So I attempted to resample my source volume with the max bounds, center and voxel size settings of the sim, but there are still lots of intermediate values generated during sourcing. Another approach was to use "gas match field" to match my flame field to my source vdb. That worked nicely but the field wont be resized anymore, which isnt good when advecting. So how could i align my volume sources voxels perfectly with my (sparse) pyro sim? pyro_match_source.hiplc Edited October 16, 2020 by nuki Quote Link to comment Share on other sites More sharing options...
Skybar Posted October 16, 2020 Share Posted October 16, 2020 Not exactly sure what is going on, but if you unlock the smokeobject and change the Voxel Sampling to Edge XZ on the flame field it will match. Thats the only thing I changed. Or you can transform your source field with half a voxelsize in X and Z (0.015 in this case), seems to have the same effect pretty much. 1 Quote Link to comment Share on other sites More sharing options...
nuki Posted October 17, 2020 Author Share Posted October 17, 2020 (edited) Yea, it seems offset by half voxelsize - wondering if its the sampling position of the noise. maybe the offset is needed so @P points def to voxel center. Resampling the source to the max bounds before applying the noise also works. I had no idea that I could change the Voxel Sampling Edge! Thanks a lot man! Edited October 17, 2020 by nuki Quote Link to comment Share on other sites More sharing options...
