nearpoint() loop/exclude group.
Martin B
I've found a few threads on this but still can't get it to work. I have a bunch of curves and I want to find the distance to the nearest point that isn't part of the same curve. Each curve has its own @id.
So my thinking was to use nearpoint(), if the @ptnum it returns has the same @id as the current point, run it again excluding that point, so it'll loop until it finds a point with a different @id. But for the life of me I can't get it to build a group/list for points to ignore.
If I manually make a @group_ignore or a string "ignore" it'll work for the first @id, but I can't get it to update for the next curve.
Below is roughly where I'm at with it, though Houdini crashed, I know the ignore section is wrong.
Thanks for any help!
int closept = nearpoint(0, @P); // find closest point
string ignore = ""; // empty string to build list in
while(@id == point(0, "id", closept)) // check if found point matches current points @id
    ignore = ignore + sprintf(" %g", closept); //Trying to make a list for nearpoint to ignore
    closept = nearpoint(0, !ignore, @P); // check for the nearest point ignoring already checked points
i@closept = closept;
Edited by Martin B
So I can get it working using nearpoints() with the below VEX but it feels horribly inefficient, and I'll need to make sure the maxdist and maxpoints on the nearpoints() are dialled in which seems silly...
  Quote
int closept[] = nearpoints(0, @P, 5, 20); // find 20 nearest points within 5 units
foreach(int nb_ptnum; closept) // loop through array
    if (point(0, "id", nb_ptnum) != @id) // checking if @id's match
        i@test= nb_ptnum;
        break;
Expand
Edited by Martin B
Hello Martin !
As you noticed, there is a ptgroup argument to the nearpoint function.
If we read the description, this part is very interesting.. "[...] Can be a SOP-style group pattern such as 0-10 or @Cd.x>0.5. [...]"
What that means is that you can do some nice inclusion/exclusion based on not only point groups per se, but even attributes on your geometry !
This odForce thread talks about this.
So in your case, what you want is to find the nearest point that does not have the same id value as the current one.
This might be a bit confusing, but this is the logic I went through while investigating this.
So, keeping in mind that the ptgroup should be a string (check the doc), something like "@id != @id" should do it ?..
But this doesn't work. For what I understand is that since this is SOP-style statement, it works a bit different than in VEX, and doesn't have direct access to the attribute value of the current point.
So instead of trying to get the current id value in the statement, we should get it "outside".
Since this is a string, we can use the sprintf function to "insert" the id value into it. And thus, "sprintf("@id != %d", i@id)".
I don't know if I'm making any sense, so here's a gif of my solution
I run for a single point for example sake, coloring the source green and the found point red.
Hope that helps !
nearpointWithGroup.hipncFetching info...
adhoc group syntax feels more elegant but it's not always an automatic win in performance. Every unique adhoc group in a pcfind (what nearpoints internally calls) call will construct a new acceleration data structure which is very costly in performance. Depending on your use case, your overhead of constructing new acceleration data structures might surpass the performance cost of skipping the points on the original curve.
Best to profile it using your input :)
@Librarian HIP attached, the swirly lines are from one of entagma's tutorials. SOP solver with a curl noise. Play the timeline from the resample to get a nice frame, then you can click down the nearpoint() wrangle which is quite heavy.
@animatrix Yep I just had a lockup when houdini went over 64gig with a load more points... Would you have any pointers on how to avoid the adhoc grouping? I had a thought on using a for-each piece SOP, then do the nearpoint() to a second input which has the current piece removed, no need for any grouping.
trailSwirl_v07_clean.hiplc
  • Thanks 1
