Add Point At End And At Start Of A Curve
sanostol
Hi again,
I want to add Points to a curve, one at the beginning and one at the end and both should be placed on the tangent of the curve ( at the start or the end). The add Sop allows adding a point at the end, but how can I inverse the curve to add another point at the other end. Stuck... :unsure:
Maybe You can give me some hints.
Martin
Hi again,
Martin
I'm not sure if this is what you'd want, but perhaps using a Sort SOP and set it to reverse the order of the points would help?
