logix1390 Posted October 29, 2020 Share Posted October 29, 2020 hello. I am trying to set color to the points in the array that the nearpoints function found. I am trying to set it in a foreach loop. However, it is not working for some strange reason. I'm sure im going wrong somewhere. Here it is: i[]@ptarray = nearpoints(1, v@P, chf("maxDist"), 133); foreach(int pt; @ptarray){ setpointattrib(0, "Cd", pt, {1,0,0}); } foreachloop_setpointattrib.hipnc Quote Link to comment Share on other sites More sharing options...
bunker Posted October 29, 2020 Share Posted October 29, 2020 The logic doesn't work: nearpoints() will give you point numbers from the second input, they have nothing to do with the first input point numbers. Here are 2 simple ways of doing what you want, just testing if you get at least one point within a search radius. // 1) nearpoint int pt = nearpoint(1,@P,chf("maxDist")); if(pt!=-1)@Cd={1,0,0}; // 2) pointcloud if(pcnumfound(pcopen(1,"P",@P,chf("maxDist"),1))>0)@Cd={1,0,0}; Quote Link to comment Share on other sites More sharing options...
logix1390 Posted October 30, 2020 Author Share Posted October 30, 2020 @bunker Thank you for the examples Bunker. Makes sense now Quote Link to comment Share on other sites More sharing options...
