ShkYo30 Posted November 2, 2020 Share Posted November 2, 2020 Hi everybody ! I've 3 different paths (curves), the 1st one is fixed, the 2nd rotate and the 3td is fixed too. I want my object follow these 3 paths one after the other. How can I do that ?? Many thanks in advance for your answers… Quote Link to comment Share on other sites More sharing options...
PixelNinja Posted November 8, 2020 Share Posted November 8, 2020 I think the simplest way would be to simply join the three paths into one. Quote Link to comment Share on other sites More sharing options...
Ultraman Posted November 8, 2020 Share Posted November 8, 2020 is simple - but maybe work for you curves.hip Quote Link to comment Share on other sites More sharing options...
ShkYo30 Posted November 15, 2020 Author Share Posted November 15, 2020 Thanks for your answers guys! For now, I've merged them inside a new geometry node, and after I can use them like a path. It's not the better way, because I've have still some problems with 360° rotation around Y axis, the object "jump" on the path when the rotation be higher than 180° ... I think this is because the order of numbering change after 180° But anyway I need to think about your example Ultraman (thanks!), I think it can be interesting ! Quote Link to comment Share on other sites More sharing options...
