polysplit issue
scuy
polysplit result strongly depends on the curve input and the tolerance aswell. I get acceptable results for tolerance = 1e-8 in polysplit. To avoid artifacts (after polysplit loop), you can use connectivity node (after foreach) without for type = prim and seam group = split. Probably there might be better workarounds.
Q_split_mod.hipnc
