[Resolved][Solaris] usd_getbbox Vex functions return Huge incorrect values
scodyscody
I'm running into a small problem trying to automate a Daily Tool.
Basically I want to be able to get the BBox of my asset to transform them accordingly next to each other for presentation.
Only Problem is when I query the Bbox_size or min,max,etc... using the Vex functions(usd_getbbox_size)
houdini returns values that are huge (bboxSize = {-6.80565e+38,-6.80565e+38,-6.80565e+38}).
Which makes it basically unusable.
I don't know wether it's a bug Or I'm using it wrong.
Thank you very much in advance!
Antonino
Here is my vex snippet:
//=========== Parameters =============//
string parentPath = usd_parentpath(0, @primpath);
//----------- String Path Par
string wildCardAsset = "/cube1";
//----------- Setting Bbox Par
vector bbox_size = usd_getbbox_size(0,wildCardAsset,"Render");
printf("bboxSize = %g",bbox_size);
usd_getbboxsize.hipnc
Edited by scodyscody
1 hour ago, malexander said:
I believe that means that the bbox is invalid, likely because the extents weren't authored on the prim.
I found the problem it was due to my "purpose tag" was incorrect!
I changed it to proxy for my mesh and I got the correct values
Thanks!
