Robse Posted November 23, 2020 Share Posted November 23, 2020 Dear od|force community, I created a simple vellum setup in order to build upon this for a future project, but I was encountering some weird stitching behaviour. Do you guys have any idea, why some of the cloth panels are not connected to the rest? I can't figure it out Best regards, Robin stitches.hip Quote Link to comment Share on other sites More sharing options...
Noobini Posted November 24, 2020 Share Posted November 24, 2020 - define cloth first THEN, do the stitches by default, you don't even need the stitch group....think of a grid, randomly edgefracture it...then stitch without defining any group...just works....test it out, should take you 2 mins to verify this. stitches_fix.hipnc Quote Link to comment Share on other sites More sharing options...
Robse Posted November 24, 2020 Author Share Posted November 24, 2020 Thanks a ton Noobini for your quick response! I have to take some time with your file today I tested having the stitches first and the cloth sop after and the other way round. Both created the same results. Even though your method does the job perfectly, I still wonder why my approach gives me stitches for the first few panels and after 4 panels it does not apply the stitches anymore...?! Where is the logic? Quote Link to comment Share on other sites More sharing options...
Noobini Posted November 24, 2020 Share Posted November 24, 2020 12 hours ago, Robse said: Thanks a ton Noobini for your quick response! I have to take some time with your file today I tested having the stitches first and the cloth sop after and the other way round. Both created the same results. Even though your method does the job perfectly, I still wonder why my approach gives me stitches for the first few panels and after 4 panels it does not apply the stitches anymore...?! Where is the logic? it is very odd now that I had a second look. The secret sauce is the sizey of your grid, yours is 0.9, mine is 1.0. (i also left my stitch at default prims instead of points, no group needed) At certain size, it refuses to work, tried it with weld, same thing. However, if you use glue it works for all sizes. why glue works for all sizes when stitch/weld don't, i don't know...maybe go log a bug with SESI. Quote Link to comment Share on other sites More sharing options...
