hindukush Posted November 26, 2020 Share Posted November 26, 2020 Hi everybody! I'm working on a soap bubble effect. The result using 2d pyro is pretty good but i would like to avoid color blending.Like would be if was pops sim. Both results are attached. Ty in advance! Carlo Quote Link to comment Share on other sites More sharing options...
Librarian Posted November 26, 2020 Share Posted November 26, 2020 Not like This? Quote Link to comment Share on other sites More sharing options...
hindukush Posted November 26, 2020 Author Share Posted November 26, 2020 Yes, in your example i see much less blending.May you try to add rgb colors and see if it works properly? How did you acheive that? Thakns alot! Carlo Quote Link to comment Share on other sites More sharing options...
Librarian Posted November 26, 2020 Share Posted November 26, 2020 You have in examples in Dop how to use divergences and volumes plus i have only this in mine Volume grid If its this That you need .. Quote Link to comment Share on other sites More sharing options...
hindukush Posted November 26, 2020 Author Share Posted November 26, 2020 Thanks man! Im not skilled enough to get what you did there:-(Where do you feed color in that volume? And also can't find that example file...ty again..and sorry for noobness:-) Carlo Quote Link to comment Share on other sites More sharing options...
Librarian Posted November 26, 2020 Share Posted November 26, 2020 Absolute not Noobness I learned this today so always learning with Houdini. i didn't know that you need to have some Kinda Skill hm ..check this Chanel you have files with similar approach. Quote Link to comment Share on other sites More sharing options...
