break dop constraints in python dop solver
catchyid
I am using Script solver inside a DOP RBD bullet sim, I was able to change velocities of individual RBD packed objects, however I don't know how to access/modify constraints network parameters (e.g strength, add/remove broken group, etc.)? The constraint network in defined globally "Relationships" subdata (i.e. not attached to each object), below is the code I am trying to write :
from __future__ import with_statement
def solveForObjects( solver_data, new_dop_objects, existing_dop_objects, time, timestep):
    dopsim = solver_data.simulation()
    relationships   = dopsim.findRelationship("constraintnetwork1")
    constraintsnetwork = relationships.findSubData("constraintnetwork") # geometry lives inside 'constraintnetwork' subdata
    geo = constraintsnetwork.findSubData("Geometry") #that works, but it's not a hou.Geometry that can be edited!
    with    constraintsnetwork.editableGeometry() as geo: #error: AttributeError: 'DopData' object has no attribute 'editableGeometry
        #.... do something here
  • 9 months later...
  On 11/29/2020 at 3:34 AM, catchyid said:
Expand
u should just modify some code,like this:
def solveForObjects(solver_data, new_dop_objects, existing_dop_objects, time, timestep):
    frame=time/timestep
    sim=solver_data.simulation()
    cnst_rel=sim.findRelationship('constraintnetwork1')
    for dop_object in existing_dop_objects:
        with cnst_rel.editableGeometry('constraintnetwork/Geometry') as geo_cnst:
            for prim in geo_cnst.prims():
                if(prim.attribValue('angle')>.2):
                    prim.setAttribValue('constraint_name','Glue')
