hid Posted December 2, 2020 Share Posted December 2, 2020 I am struggle how to remove the inner line after boolean for drawing contour. I know that line comes because of connecting primitive as same height, but the both side of points are not neighbor so they are random... If you know how to remove that line, I would like you to tell me. Quote Link to comment Share on other sites More sharing options...
ikoon Posted December 2, 2020 Share Posted December 2, 2020 (edited) Hi, you may try the Hole SOP. It has an "Un-bridge Holes" option. Edited December 2, 2020 by ikoon typo Quote Link to comment Share on other sites More sharing options...
hid Posted December 3, 2020 Author Share Posted December 3, 2020 @ikoon Thank you for good solution! That works well. I appreciate you~ Quote Link to comment Share on other sites More sharing options...
hid Posted December 3, 2020 Author Share Posted December 3, 2020 Sorry, though that solution works for still image, I realized those line come up if I try to animate. Maybe Boolean SOP is not good for animation.. Or if you know the solution, I would like to try. Thank you boolean animation.mov Quote Link to comment Share on other sites More sharing options...
ikoon Posted December 4, 2020 Share Posted December 4, 2020 Hi, you may try other approaches, try to google Houdini isolines, or contour lines, terrain curves. For example here on odforce: https://forums.odforce.net/topic/40535-heightfield-isolines/ https://forums.odforce.net/topic/28306-topo-lines-terrain-curves/ Quote Link to comment Share on other sites More sharing options...
Librarian Posted December 4, 2020 Share Posted December 4, 2020 WE had That File from 2016 you can use any gradient on any shape, Houdini its all about Colors----------------->link vector bb=getbbox_size(0); vector bmax=getbbox_max(0); vector bmin=getbbox_min(0); float green_line=chf("GreenLine"); if(green_line!=1.0) @Cd=set(abs(fit(@P.y,fit01(green_line,bmin.y-bb.y,bmax.y),bmax.y,0,1))*0.5,fit(@P.y, bmin.y, bmax.y, 0.5, 1),abs(fit(@P.y,fit01(green_line,bmin.y-bb.y,bmax.y) ,bmax.y,0,1))*0.5); else @Cd=set(0.0, fit(@P.y, bmin.y, bmax.y, 0.5, 1), 0.0); Quote Link to comment Share on other sites More sharing options...
hid Posted December 6, 2020 Author Share Posted December 6, 2020 Thank you very much! Those tips should make me draw nice image! Quote Link to comment Share on other sites More sharing options...
